I have a process where I pull data from multiple sources, and one step along the way is to filter data to match a date range. To do this I calculate a start date and end date and then build those into a sql expression, however I've noticed the query expression has to be constructed slightly different between two uses, here's an example:
qry = "CREATED_DATE >= '" + startdate + "' AND CREATED_DATE <= '" + enddate + "'"
apd_lyr = arcpy.MakeFeatureLayer_management(crime_data,"apd_crimes", qry)
but in another use of this same pattern code ends up looking like this, with the keyword 'timestamp' added:
qry = "REPORTDATE >= timestamp'" + startdate + "' AND REPORTDATE <= timestamp '" + enddate + "'"
raw_CED_dates = arcpy.MakeTableView_management(raw_CED,'ced_dates',qry)
is there any particular reason these two query strings need to be constructed slightly differently, or is this just an oddity in ArcPy? Both queries are working against date fields (CREATED_DATE and REPORTDATE).
