I'm currently facing an issue when trying to run my tests in my vue3 project, the fetch is running normally without any issues but the tests are failing for unknown reason, I have found a similar issue but I'm using a different version than that: https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/why-is-esrirequest-not-working/td-p/623384
Current lib versions:
vue: v3.2
@ArcGIS/core v4.27.5
vitest v0.24.3
This is my function which I'm getting the error from:
const fetchAddressReverse = async (lng, lat) => {
const apiRequest = await esriRequest(searchApiCredentials.esriSearchUrl, {
query: {
token: directionsApiCredentials.esriToken,
f: 'json',
if (!apiRequest || !apiRequest.data?.address || !apiRequest.data.address?.LongLabel) return null
return transformAddress(apiRequest.data.address?.LongLabel)
And when I run my tests I'm getting this error:
⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯ Unhandled Errors ⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯
Vitest caught 1 unhandled error during the test run.
This might cause false positive tests. Resolve unhandled errors to make sure your tests are not affected.
⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯ Unhandled Rejection ⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯⎯
TypeError: Right-hand side of 'instanceof' is not an object
❯ K node_modules/@arcgis/core/request.js:5:3388
❯ V node_modules/@arcgis/core/request.js:5:8091
❯ Proxy.j node_modules/@arcgis/core/request.js:5:2032
❯ Object.fetchAddressReverse src/service/external/geo/useGeoService.ts:84:23
82| */
83| const fetchAddressReverse = async (lng, lat) => {
84| const apiRequest = await esriRequest(searchApiCredentials.esriSearchUrl, {
85| query: {
86| token: directionsApiCredentials.esriToken,
