I have an Experience which has some pages that have 3 maps each showing a variable at a different time. The maps are linked so that if the user zooms/pans to an area in one map, the other 2 maps also move to that location.
The maps contain a tiled imagery layer that has a popup that shows the pixel value at that location. Since there are 3 maps on the screen, the pop-up display opens up in an un-expanded mode. If you then expand the popup so you can see the data, the maps zoom to another location where the map is centered on the area off the coast of Rancho Palos Verdes.
If I expand the map to full screen, the popup is expanded and this behaviour doesn't happen. Also, I have some pages with just 2 maps on a page and the expansion of the popup works as expected.
You can see this at: https://experience.arcgis.com/experience/f4c4934c5d7548adabe9c44cf5462393/page/Temperature/?views=Avg-Max-Temp---Hotter-
Click on any colored part of any of the 3 maps, expand the popup and the map will move. It is more apparent the more you zoom in on the map. For example, search for Hemet, click there and then expand the popup window.
Does anyone have any ideas why this is happening? Hopefully it's just a setting somewhere.
Thanks!
