I'm wondering if anybody can help me find the best way to achieve my goals.
I have set up a Survey123 that users fill up when they go on the field. If something needs a follow up/an intervention of some sort, they check the appropriate field in the form.
Then, when they come back in the office, they can consult the necessary work that needs to be done. When this work is done, they should be able to change some property (checkbox, drop down list, radio button...) that updates the data in the source and thus it won't be shown anymore as "follow up needed".
I had setup a whole dashboard for this but now I realize I guess you can't update the source from it (meaning you can see the work that needs to be done but you can't remove it from this list once the work is done).
Is there another AGOL tool better suited for this?
Thanks!
