I am trying to automate a certain workflow and in the process need to change the layer properties > Time > Layer Time to "Each feature has a single time field". I tried to create a separate python script outside the ArcGIS Pro environment, but failed to import the arcpy module.
I have since tried to create a python notebook within ArcGIS Pro to connect to the layer, but I am unsure as to how to write the script to perform the above action.
Additionally, will I be able to run this script from outside the ArcGIS Pro environment without having to open the aprx file?
This is my code so far
import arcpy
# Setting the workspace (geodatabase or folder containing your data)
arcpy.env.workspace = r"C:\Users\manognat\Documents\ArcGIS\Projects\Workzone-Crash Association\Workzone-Crash Association.gdb"
# Setting the map document
aprx = arcpy.mp.ArcGISProject(r"C:\Users\manognat\Documents\ArcGIS\Projects\WorkZoneTest\WorkZoneTest\WorkZoneTest.aprx")
# Accessing a specific map in the project
map = aprx.listMaps("Map")[0]
# Accessing a specific layer in the map
layer = map.listLayers("LayerName")[0]
I need the script to be able to automate the following functionality:
Right click on the layer –“LayerName”, then select Properties, then select Time, then set “Layer Time” to “Each feature has a single time field” and save.
Any help is greatly appreciated.
