I wonder if anyone else has seen this behavior, it has happened to me several times. Pro will try and launch properties or some other pop-up menu, it then fails to open but the application is stuck thinking that the pop-up is still visible so you can't interact with the main window. It frustratingly then just beeps at you like your an idiot for not using the other window which doesn't exist. I've had to then end the process every time because it is stuck in a UI/UX dead end.
Has anyone experienced this or figured out a work around?
