In Experience Builder I am trying to configure a page to have two map layer widgets, each showing a subset of themed layers with the aim of users just flipping between widgets to turn on/off layers in the main map pane (easily done in the old WAB).
What is the correct way to do this (assuming there is a way!)? I have tried having all data in one web map with the aim of sub-setting layers out to each map layer widget, then you get the message related to:
You cannot access the Customize layers setting if multiple Map Layers widgets are connected to the same Map widget.
I also can't seem to take advantage of having two web maps connected to one map widget; so ideally want to link map layer widget 1 to web map 1, map layer widget 2 to web map 2 etc.
What am I missing!?
