Hi Everyone,
I have a dataset that has different variables per county. But when I change variables the scale of the arcGIS map isn't adjusted manually. So, for example the first variable will vary from 0-20, and when I select a new variable that ranges from 0-200 the colors don't adjust and it just shows the whole map as grey. I can change the colors by adjusting the settings every time I change variables, but is there a way to make this change happen automatically every time the variable is changed?
Thanks in advance!
after changing to variable with different scale
