I'm wondering if anyone can share some insight into what's happening under the hood when linear distances are measured in field maps.
I am using a web map that is built on a basemap using web mercator (WKID 3857).
I am measuring using the measure tool and using the automated length measurements of a hosted line feature layer in WKID 3857.
My location profile uses GCS NAD 1983 2011 (6318) as the GNSS Coordinate System and WGS 1984 Web Mercator Auxiliary Sphere (3857 as the Map Coordinate System. The datum transformation is ~WGS_1984_(ITRF08)_To_NAD_1983_2011. This is in Field Maps 23.1.0 Build 984.
When I measure a line on the map between two points collected with high-accuracy GPS, it is usually within an inch or two of the same distance measured with a tape measure. This obviously depends on the accuracy of the GPS, but it's close enough that I'm confident it is not measuring in web mercator. The distortion on this line is more than 30' when measured under web mercator in ArcPro.
This is good, but I want to understand how it's getting there. I had assumed it would be measuring in web mercator, because the base map and feature layer are in web mercator, and the location profile is using web mercator as its coordinate system.
Is field maps measuring geodesic distance? Using the GNSS Coordinate System? Using an on-the-fly projection based on the location profile extent, or map extent? Choosing an appropriate state plane?
The closest related post I could find was this one, which doesn't really dive into projections:
https://community.esri.com/t5/arcgis-field-maps-questions/field-map-measurements-which-is-correct/m-p/1245258
Thank you,
