Hi,I'm using 'Display identify results in popup' sample and try to add 2 or 3 ArcGISDynamicMapServiceLayer. How do i configure the code so that the popup will show result of selected ArcGISDynamicMapServiceLayer.Thank <!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Identify with Popup</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height:100%; width:100%; margin:0; padding:0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/InfoTemplate", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "esri/dijit/Popup", "dojo/_base/array", "esri/Color", "dojo/dom-construct", "dojo/domReady!" ], function ( Map, InfoTemplate, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol, IdentifyTask, IdentifyParameters, Popup, arrayUtils, Color, domConstruct ) { var identifyTask, identifyParams; var popup = new Popup({ fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25])) }, domConstruct.create("div")); map = new Map("map", { basemap: "satellite", center: [-83.275, 42.573], zoom: 18, infoWindow: popup }); map.on("load", mapReady); var parcelsURL = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/BloomfieldHillsMichigan/Parcels/MapServer"; map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL, { opacity: .55 })); function mapReady () { map.on("click", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new IdentifyTask(parcelsURL); identifyParams = new IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 2]; identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; } function executeIdentifyTask (event) { identifyParams.geometry = event.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask .execute(identifyParams) .addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return arrayUtils.map(response, function (result) { var feature = result.feature; var layerName = result.layerName; feature.attributes.layerName = layerName; if (layerName === 'Tax Parcels') { var taxParcelTemplate = new InfoTemplate("", "${Postal Address} <br/> Owner of record: ${First Owner Name}"); feature.setInfoTemplate(taxParcelTemplate); } else if (layerName === 'Building Footprints') { console.log(feature.attributes.PARCELID); var buildingFootprintTemplate = new InfoTemplate("", "Parcel ID: ${PARCELID}"); feature.setInfoTemplate(buildingFootprintTemplate); } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. map.infoWindow.setFeatures([deferred]); map.infoWindow.show(event.mapPoint); } }); </script> </head> <body> <div id="map"></div> </body> </html>
