Goal is to copy a list of the most resent attributes from a related table back to the Related Feature Class.
The feature class is called SampleSites, the related table is for collecting water samples for the that site.
Inspection Table is related to the Sample Sites GolbalID field and stored in a field called "SampleSites_Rel" in the Inspection Table
The Expression I am using now only gets the first record of the "inspection" variable in the Filter, I have tried "Max" and was not successful, I have tried to Sort the Table and failed " I had a wrong number of arguments" trying to add the sort to the expression.
var vFeature_SampleSiteGlobalID = $feature.GlobalID;
var InspectionTable = FeatureSetByName($datastore, "SDEP.SDEADMIN.WaterSampleInspections");
var Inspection = Filter(InspectionTable, "SampleSites_Rel = @vFeature_SampleSiteGlobalID");
var sv = first(Inspection);
if (sv != null) {
return {
"result" : {
"attributes" : {
"SampleDate" : sv.SampleDate,
"Cl" : sv.Cl,
"pH" : sv.pH,
"NH3" :sv.NH3,
"Color" :sv.Color,
"Temperature" : sv.Temperature,
"HPC" : sv.HPC
Any help would be much appreciated
