We have problems with creating default elevation layer.
This layer should be default elevation when you open new Global/Local scene in Pro and when you open a new web scene in Portal.
We are using version 10.9.1 and all our base maps are Geo wgs84 (not web Mercator).
We would like to build the cache before publishing using Pro to save the cache creation from the server.
We did a few tests. Some works for Pro other works for web scene, none works for both.
The source data in Mosaic with dtm's tiles.
We understand we need to build the cache in LERC compression but we are not sure how to publish it (image service? elevation service?) what are the cache levels? and how to make it use the pre-created cache.
