Is there a limit to the available data in a feature layer to be filtered? For example, I have probably 12K+ features in a layer and one of the fields may have several thousand unique entries that I need users to be able to filter in the mobile app. When pulling up the filter for a field, 70+ features are already visible to choose from. Typing in the data to be filtered, it only seems to look in the pre-populated features mentioned earlier. It does not look through all 12K+ features. I get a "No results found matching..." I know the feature is there because when I search for it, I find it without issue.
I do have the filters setup for the field I am searching within. Any ideas what could be happening or is my hunch correct that there is a limit? Thank you.
