I want to check if a field type is text to change this field to type double so that I can use it as input field into XYTableToPoint?
This if statement in line 16 doesn't work (arcgis pro 3.0 notebook)
Any ideas?
Error message for line 41:
ERROR 000308: Ungültiger Feldtyp
for f in files_list:
print (f)
outTable = "tab_" + os.path.splitext(os.path.basename(f.replace("-", "_")))[0]
outXY = "s_" + os.path.splitext(os.path.basename(f.replace("-", "_")))[0]
arcpy.conversion.ExcelToTable(f, outTable)
x = "R_Wert"
y = "H_Wert"
fields = arcpy.ListFields(outTable)
field_names = []
for field in fields:
field_names.append(field.name)
if field.name == x and field.type == "TEXT":
print("Wrong type")
arcpy.management.AddField(outTable, "R_Wert_1", "DOUBLE")
arcpy.management.CalculateField(outTable, "R_Wert_1",
'!R_Wert!', "PYTHON3")
x = "R_Wert_1"
elif field.name == y and field.type == "TEXT":
print("Wrong Type")
arcpy.management.AddField(outTable, "HWert_1", "DOUBLE")
'!H_Wert!', "PYTHON3")
y = "H_Wert_1"
else:
continue
if x in field_names and y in field_names:
print("Field names ok")
arcpy.management.XYTableToPoint(outTable, outXY,
x, y, "",
arcpy.SpatialReference("DHDN 3-Degree Gauss Zone 3"))# ('ETRS 1989 UTM Zone 32N'))
else:
print("Field names wrong")
continue
