I converted an annotation layer created in ArcMap, and published it as a Map Image Layer from Pro. It gives a warning about fonts, but I have installed the fonts on both my Portal and Server machines. When it renders in Map Viewer Classic, I see it's substituted Arial for the Shadow font.
I know the font is available on the server. See "Astoria" rendered erroneously in Arial here and the Popup with text that I set to Shadow by changing the HTML.
Is there a way to convince Server not to make everything Arial? Maybe a style or css page somewhere??
Here is what the map looks like in ArcGIS Pro, using the map used to publish the MIL. Look at the label "Astoria" in Shadow,
