Hi there,
I'm trying to import data from a local file geodatabase into an Enterprise Geodatabase. The file geodatabase is relatively large, approx. 30gb. When I ran the import through the UI it took over 16 hours using ArcPro 3.0! The machine I'm using to run the import isn't the most powerful, but it isn't the worst either. After I ran this I realised it didn't copy across the relationship files and non-spatial files (completely my fault). I am changing my approach and I am going to export the file geodatabase as an XML and then import it into the server using import from XML but even the export is taking too long.
Is there any other approach I could take to speed this up? It's pretty ridiculous the export/import takes so long.
