Hello,I am trying to create a widget that will geolocate an address using bing, then create a buffer around from that geolocated location. I have used the FLEX API Library BufferSample.mxml, VEGEOCODER.mxml, to start development of the widget. I am having trouble passing a variable that contains the geometry of the point found from the geocoder to the buffer. Any suggestions on how to do this?Also is there a problem with the geometry:Polygon in event.result. This part of the code used to run under a mouse_click event while now it's a button click event. Could I use the VEGeocoder.addressToLocationsComplete event somehow?Thanks,Tristan EDIT: I was able to get it to work, now trying to fix the extent so that it is the extent of the buffer and not of the point.<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:esri="http://www.esri.com/2008/ags"
xmlns:s="library://ns.adobe.com/flex/spark"
pageTitle="Bing Geocoding with ArcGIS API for Flex">
This sample shows how to find the address (aka geocoding) for a certain address.
The solution is to use the addressToLocations() method on the VEGeocoder.
In this sample a user-provided address is sent to the server
for geocoding. When the response comes back, the onResult()
function creates a graphic for the result and then sets the
map extent to the best view extent of the result.
To use VETiledLayer/VEGeocoder you will need access to Bing Maps (formerly Microsoft Virtual Earth).
See "Concepts" in the Resource Center for details.
http://help.arcgis.com/en/webapi/flex/help/index.html#ve_gettingstarted.htm
<!-- Resources
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/samples/index.html?sample=FreehandBufferGP
http://resources.esri.com/help/9.3/arcgisserver/apis/flex/help/Content/ve_geocoding.htm
http://forums.esri.com/Thread.asp?c=158&f=2421&t=281389
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=LabelPoints
<!-- Start Declarations -->
<fx:Declarations>
<!-- Replace this sample Bing key with your own Bing key, see http://help.arcgis.com/en/webapi/flex/help/index.html#ve_gettingstarted.htm -->
<fx:String id="bingKey">AkzyGe3XdTPn1o1S0oJQT4c1rLDE_gjEOANKPmn0vAFYWZTHWa9L9ZmQ1picf5Sm</fx:String>
<esri:VEGeocoder id="veGeocoder"
culture="en-US"
key="{bingKey}"/>
<esri:SimpleMarkerSymbol id="mySymbol"
alpha="0.5"
color="0xFF0000"
size="19"
style="circle">
<esri:SimpleLineSymbol width="2"/>
</esri:SimpleMarkerSymbol>
<esri:SimpleFillSymbol id="sfs" color="0xFF0000">
<esri:SimpleLineSymbol color="0x000000"/>
</esri:SimpleFillSymbol>
<esri:GeometryService id="myGeometryService" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
</fx:Declarations>
<!-- End Declarations -->
<fx:Script>
<![CDATA[
import com.esri.ags.Graphic;
import com.esri.ags.SpatialReference;
import com.esri.ags.events.GeometryServiceEvent;
import com.esri.ags.events.VEGeocoderEvent;
import com.esri.ags.geometry.Extent;
import com.esri.ags.geometry.MapPoint;
import com.esri.ags.geometry.Polygon;
import com.esri.ags.tasks.supportClasses.BufferParameters;
import com.esri.ags.utils.WebMercatorUtil;
import com.esri.ags.virtualearth.VEGeocodeResult;
import mx.controls.Alert;
import mx.rpc.AsyncResponder;
import mx.rpc.Fault;
private function doFind():void
veGeocoder.addressToLocations(address.text, new AsyncResponder(onResult, onFault));
function onResult(results:Array, token:Object = null):void
if (results.length > 0)
var veResult:VEGeocodeResult = results[0];
var myGraphic:Graphic = new Graphic();
myGraphic.geometry = WebMercatorUtil.geographicToWebMercator(veResult.location);
myGraphic.symbol = mySymbol;
myGraphic.toolTip = veResult.displayName;
myGraphic.id = "graphic";
myGraphicsLayer.add(myGraphic);
myMap.extent = WebMercatorUtil.geographicToWebMercator(veResult.bestView) as Extent;
//myMap2.extent = WebMercatorUtil.geographicToWebMercator(veResult.location) as Extent;
myInfo.htmlText = "<b>Found:</b><br/>" + veResult.displayName;
//Create the Buffer and set the Parameters
var myMapPoint:MapPoint = MapPoint(myMap.extent.center);
var bufferParameters:BufferParameters = new BufferParameters();
// Note: As of version 2.0, the GeometryService input is geometries (instead of graphics).
bufferParameters.geometries = [ myMapPoint ];
//User input for Buffer Distances in km
bufferParameters.distances = [ 50, 100 ];
// Note: As of version 2.0, the buffer constants have been moved to GeometryService.
bufferParameters.unit = GeometryService.UNIT_KILOMETER;
//Spatial Reference for Web Mercator is (102113) Mercator Geographic is (4326)
bufferParameters.bufferSpatialReference = new SpatialReference(102113);
bufferParameters.outSpatialReference = myMap.spatialReference;
//bufferParameters.outSpatialReference = new SpatialReference(102113);
myGeometryService.addEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler);
myGeometryService.buffer(bufferParameters);
function bufferCompleteHandler(event:GeometryServiceEvent):void
myGeometryService.removeEventListener(GeometryServiceEvent.BUFFER_COMPLETE, bufferCompleteHandler);
// Note: As of version 2.0, GeometryService returns geometries (instead of graphics)
for each (var geometry:Polygon in event.result)
var graphic2:Graphic = new Graphic();
graphic2.geometry = geometry;
//graphic2.geometry = WebMercatorUtil.geographicToWebMercator(veResult.location);
graphic2.symbol = sfs;
myGraphicsLayer.add(graphic2);
else
myInfo.htmlText = "<b><font color='#FF0000'>Found nothing
</b></font>";
Alert.show("Sorry, couldn't find a location for this address"
+ "\nAddress: " + address.text);
function onFault(fault:Fault, token:Object = null):void
myInfo.htmlText = "<b>Failure:</b> " + fault.faultString;
Alert.show("Failure: \n" + fault.faultString, "VEGeocoder problem");
</fx:Script>
<esri:Map id="myMap">
<esri:extent>
<esri:Extent xmin="-13046644" ymin="4028802" xmax="-13024380" ymax="4040893">
<esri:SpatialReference wkid="102100"/>
</esri:Extent>
</esri:extent>
<esri:VETiledLayer id="veTiledLayer"
culture="en-US"
key="{bingKey}"
loadError="Alert.show(event.fault.faultString, 'VETiledLayer loadError')"
mapStyle="road"/>
<esri:GraphicsLayer id="myGraphicsLayer"/>
</esri:Map>
<s:Panel top="5"
horizontalCenter="0"
title="Find an address">
<s:layout>
<s:VerticalLayout/>
</s:layout>
<mx:Form>
<mx:FormItem label="Address">
<mx:TextInput id="address"
width="100%"
text="599 Brealey Dr, ON"/> <!-- Fleming College -->
</mx:FormItem>
<mx:FormItem>
<mx:Button click="doFind()" label="Find Address"/>
</mx:FormItem>
</mx:Form>
<mx:Text id="myInfo"
width="100%"
color="0x00FF00"
textAlign="center"/>
</s:Panel>
</s:Application>
