Hi All, I'm having an issue with zooming/panning to an extent after filtering the layer. So, my filter works perfectly however when I use a view.goTo() it sometimes zooms out and If I filter to a feature (i.e. different province) not in the current view, it doesn't move to that feature's extent. I basically want the extent to be focused on the filtered expression
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<title>
Application
</title>
<style>
html,
body {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#viewDiv {
float: right;
padding: 0;
margin: 0;
height: 100%;
width: 85%;
#feature-node {
float: left;
width: 15%;
height: 100%;
max-height: 100%;
background: #eeeeee;
padding: 1mm;
border-style: solid;
border-color: #b0aeab;
border-width: thin;
#filterDiv {
margin-top: 5px;
border-width: thin;
height: 17%;
.action {
color: blue;
cursor: pointer;
text-decoration: underline;
#rings {
padding: 10px;
.header {
height: 30px;
padding-top: 5px;
.menu {
display: table;
width: 100%;
border: 1px solid black;
border-right: none;
box-sizing: border-box;
.menu>div {
display: table-row;
background-color: white;
.menu>div>div {
border-right: 1px solid black;
display: table-cell;
text-align: center;
vertical-align: middle;
.boxpadding {
margin: 8px 0;
.float-container {
display: flex;
padding: 2px;
gap: 8px;
margin: 8px 0;
.float-child1 {
flex: 1;
.float-child2 {
flex: 2;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.24/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.24/"></script>
<script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/layers/GroupLayer",
"esri/layers/FeatureLayer",
"esri/widgets/LayerList",
"esri/widgets/Slider",
"esri/widgets/Expand",
"esri/widgets/Legend",
"esri/portal/Portal",
"esri/identity/OAuthInfo",
"esri/identity/IdentityManager",
"esri/layers/VectorTileLayer",
"esri/Basemap",
"esri/widgets/BasemapGallery",
"esri/widgets/Search",
"esri/widgets/ScaleBar",
"esri/layers/GraphicsLayer",
"esri/views/draw/Draw",
"esri/Graphic",
"esri/geometry/geometryEngine",
"esri/rest/locator",
"esri/widgets/Home"
], (esriConfig, Map, MapView, GroupLayer, FeatureLayer, LayerList, Slider, Expand, Legend, Portal, OAuthInfo, IdentityManager, VectorTileLayer, Basemap, BasemapGallery, Search, ScaleBar, GraphicsLayer, Draw, Graphic, geometryEngine, locator, Home) => {
const info = new OAuthInfo({
appId: "",
popup: false
IdentityManager.registerOAuthInfos([info]);
IdentityManager.checkSignInStatus(info.portalUrl + "/sharing").then(() => {
displayMap();
document.getElementById("panel").style.visibility = "visible"
}).catch(() => {
document.getElementById("anonymousPanel").style.display = "block";
document.getElementById("sign-in").addEventListener("click", () => {
document.getElementById("sign-in").style.display = "none";
IdentityManager.getCredential(info.portalUrl + "/sharing");
function displayMap() {
const portal = new Portal();
portal.load().then(() => {
const AVGHomeValues = new FeatureLayer({
url: "https://services7.arcgis.com/N6e25NYZwW1P8EDW/arcgis/rest/services/Average_Home_Values/FeatureServer",
title: "Average Home Values",
outFields: ["AllRegions_CSDNAME"],
minScale: 0,
maxScale: 0,
definitionExpression: "AllRegions_CSDNAME = 'Etobicoke' OR AllRegions_CSDNAME='Oakville' OR AllRegions_CSDNAME ='Victoria' OR AllRegions_CSDNAME = 'West Vancouver' OR AllRegions_CSDNAME = 'Etobicoke - Core' OR AllRegions_CSDNAME = 'Etobicoke - North' OR AllRegions_CSDNAME = 'Etobicoke - South'"
const AVGRentPaid = new FeatureLayer({
url: "https://services7.arcgis.com/N6e25NYZwW1P8EDW/arcgis/rest/services/Average_Rent_Paid/FeatureServer",
title: "Average Rent Paid",
minScale: 0,
maxScale: 0,
const wealth = new GroupLayer({
title: "Wealth",
visible: true,
layers: [AVGHomeValues, AVGRentPaid],
opacity: 1,
visibilityMode: "exclusive"
const lightgray = new VectorTileLayer({
portalItem: {
const esribasemap = new Basemap({
baseLayers: [lightgray],
title: "Light Gray (no labels)",
thumbnailUrl: Basemap.fromId("gray-vector").thumbnailUrl
const map = new Map({
basemap: esribasemap,
layers: [wealth]
const view = new MapView({
center: [-79.3832, 43.6532],
zoom: 10,
container: "viewDiv",
map: map
const basemapGallery = new BasemapGallery({
view: view,
source: [Basemap.fromId("gray-vector"), Basemap.fromId("hybrid"), esribasemap, Basemap.fromId("satellite"), Basemap.fromId("streets-navigation-vector")]
const bgExpand = new Expand({
view: view,
content: basemapGallery,
expandTooltip: "Basemaps"
basemapGallery.watch("activeBasemap", () => {
const mobileSize = view.heightBreakpoint === "xsmall" || view.widthBreakpoint === "xsmall";
if (mobileSize) {
bgExpand.collapse();
const draw = new Draw({
view: view,
var regions = {
'Ontario': ['', 'Oakville', 'Etobicoke'],
'British Columbia': ['', 'Victoria', 'West Vancouver']
var districts = {
'Etobicoke': ['', 'Etobicoke', 'Etobicoke - Core', 'Etobicoke - North', 'Etobicoke - South'],
'Victoria': ['', 'Victoria'],
'West Vancouver': ['', 'West Vancouver'],
'Oakville': ['', 'Oakville']
var regionOption = document.querySelector("#municipality");
var districtOption = document.querySelector("#districtName");
var provOption = document.querySelector("#region");
createOption(provOption, Object.keys(regions));
createOption(regionOption, regions[provOption.value]);
provOption.addEventListener('change', function() {
regionOption.addEventListener('change', function() {
createOption(districtOption, districts[regionOption.value]);
document.getElementById("districtName").addEventListener("change", () => {
view.allLayerViews.forEach((lv) => {
if (lv.layer.type === "feature") {
if (document.getElementById("districtName").value != " ") {
lv.filter = {
where: "AllRegions_CSDNAME = '" +
document.getElementById("districtName").value +
lv.watch("updating", function(val) {
if (!val) {
lv.queryExtent().then(function(response) {
view.goTo(response.extent);
function createOption(dropDown, options) {
dropDown.innerHTML = '';
options.forEach(function(value) {
dropDown.innerHTML += '<option name="' + value + '">' + value + '</option>';
function defineActions(event) {
const item = event.item;
if (item.layer.type === "group" & item.title != "Boundaries") {
const slider = new Slider({
min: 0,
max: 1,
precision: 2,
values: [1],
visibleElements: {
labels: true,
rangeLabels: true
item.panel = {
content: slider,
className: "esri-icon-sliders-horizontal",
title: "Change Opacity"
slider.on("thumb-drag", (event) => {
const {
value
} = event;
item.layer.opacity = value;
view.when(() => {
const layerList = new LayerList({
view: view,
listItemCreatedFunction: defineActions,
layerList.on("trigger-action", (event) => {
const id = event.action.id;
if (id === "toggle-labels") {
if (Neighbourhoods.labelsVisible == false) {
Neighbourhoods.labelsVisible = true;
} else {
Neighbourhoods.labelsVisible = false;
const legend = new Expand({
content: new Legend({
view: view,
view: view,
expandTooltip: "Legend"
view.ui.add(bgExpand, "top-left");
view.ui.add(legend, "top-left");
view.ui.add(layerList, "top-left");
</script>
</head>
<body>
<div id="anonymousPanel" style="display: none; padding: 5px; text-align: center;">
<span id="sign-in" class="action">Sign In</span> to view the content
</div>
<div id="panel" style="visibility:hidden;">
<div id="feature-node" class="esri-widget">
<div id="filterDiv" class="esri-widget">
<div id="filterwidget" class="esri-widget">
<h3 align="center">Filter by Region</h3>
<div class="float-container">
<div class="float-child1">
<div>Province: </div>
</div>
<div class="float-child2">
<div id="province" class="esri-widget">
<select id="region" style="width:110px;">
</select>
</div>
</div>
</div>
<div>Region: </div>
</div>
<div id="municipalities" class="esri-widget">
<select id="municipality" style="width: 110px;"></select>
</div>
</div>
</div>
<div>Districts: </div>
</div>
<div id="districtsFilter" class="esri-widget">
<select id="districtName" style="width: 110px;"></select>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
<div id="viewDiv"></div>
</body>
</html>
@Sage_Wall @ReneRubalcava @UndralBatsukh @JeffreyWilkerson
