Hi everyone,I am writing a standalone C# application for creating jpg maps that is being converted from VBA. With help from several people on the forums, I have been able to get everything working without having to use ArcMap at all. I am down to just one glitch and can't figure out how to get around it. At one point, I add a scalebar to the layout and depending on the map scale, I set the units of the scale bar to either esriMiles or esriFeet. The problem I am having is that since I am not running ArcMap and this is all being done in memory, I don't really have map scale to adjust. In the code below, I get an error at if (m_pMap.MapScale >= 25000) with an error of "The data necessary to complete this operation is not yet available." I have seen a couple of similar posts on the forums but no firm solutions. I have tried everything suggested on these threads including making sure the map has a spatial reference and units.Later on in another method, I use the map scale also to set the scale to a rounded number (24,000 instead of 24,323) since the layout also has a scale text object.How can I get/set the map scale if I am not using ArcMap?Any help is greatly appreciated!!!Carlospublic static void AddScaleBar()
try
stdole.StdFont pFont = new stdole.StdFont();
pFont.Name = "Arial";
ITextSymbol pTextSymbol = new TextSymbolClass();
pTextSymbol.Font = pFont as stdole.IFontDisp;
pTextSymbol.Size = 5;
IGraphicsContainer pGraphicsContainer = m_pPageLayout as IGraphicsContainer;
IFrameElement pFrameElement = pGraphicsContainer.FindFrame(m_pMap);
IMapFrame mapFrame = pFrameElement as IMapFrame;
IUID uid = new UIDClass();
uid.Value = "esriCarto.AlternatingScaleBar";
IMapSurroundFrame mapSurroundFrame = mapFrame.CreateSurroundFrame(uid as UID, null);
IElement element = mapSurroundFrame as IElement;
IEnvelope envelope = new EnvelopeClass();
envelope.PutCoords(1.24, 0.4, 3.58, 0.55);
element.Geometry = envelope;
pGraphicsContainer.AddElement(element, 0);
IMapSurround mapSurround = mapSurroundFrame.MapSurround;
IScaleBar pScaleBar = mapSurround as IScaleBar;
pScaleBar.Divisions = 1;
pScaleBar.Subdivisions = 2;
pScaleBar.DivisionsBeforeZero = 0;
pScaleBar.LabelSymbol = pTextSymbol;
pScaleBar.UnitLabelPosition = esriScaleBarPos.esriScaleBarBelow;
pScaleBar.UnitLabelSymbol.HorizontalAlignment = esriTextHorizontalAlignment.esriTHACenter;
pScaleBar.UnitLabelSymbol = pTextSymbol;
pScaleBar.UnitLabelSymbol.Font = pFont as stdole.IFontDisp;
pScaleBar.UnitLabelSymbol.Size = pTextSymbol.Size;
pScaleBar.Name = "scalebar";
//if map scale is greater than 25000, switch the scale units to miles
pScaleBar.Units = esriUnits.esriMiles;
else
pScaleBar.Units = esriUnits.esriFeet;
IGraphicsContainerSelect pGraphicsContainerSelect = pGraphicsContainer as IGraphicsContainerSelect;
pGraphicsContainerSelect.UnselectAllElements();
catch (Exception ex)
MessageBox.Show(ex.Message);
