This is a similar issue to what succip posted the other day. I'm trying to update Z values of a feature geometry in a RowEvent (RowCreatedEvent or RowChangedEvent), but while awaiting the Z values, it seems the feature is getting disposed. When trying to update the feature's shape in feature.SetShape(newShape), I get an ArcGIS.Core.ObjectDisconnectedException ("This object has been previously disposed and cannot be manipulated."). My code:
public async void OnRowChanged(RowChangedEventArgs args)
var feature = (Feature)args.Row;
var newShape = this.PolylineDensifier.Densify(feature.GetShape() as Polyline, MAX_LENGTH);
var result = await MapView.Active.Map.GetZsFromSurfaceAsync(newShape);
if (result.Status == SurfaceZsResultStatus.Ok) newShape = (Polyline)result.Geometry;
newShape = (Polyline)GeometryEngine.Instance.Generalize3D(newShape, GENERALIZE_OFFSET);
UpdateMs(newShape);
newShape = (Polyline)GeometryEngine.Instance.SimplifyAsFeature(newShape, true);
feature.SetShape(newShape);
}My interpretation: Since the event handler has a void return type, the method is not awaiting the GetZsFromSurfaceAsync call and the edit operation terminates (disposing the feature) before the geometry is being updated. All my other manipulations work well if I skip updating the Z values.
I also tried
var result = MapView.Active.Map.GetZsFromSurfaceAsync(newShape).Result;
But this call never terminates (deadlock).
According to Wolfs suggestion in the aforementioned post, I migth start a new EditOperation and re-update the feature there, but to me this looks awkward because my intention was to do all manipulations within the RowEvent's operation. Also, I need the manipulations to appear as one operation on the stack, so that the user cannot undo just my manipulations while the initial create/update operation is not getting undone.
How can this be achieved? Is there a way to get Z values synchronously? In ArcMap this was possible with the IFunctionalSurface.Z method, but I haven't found an equivalent in Pro (see also this post).
Updating the Zs automatically in the map via ElevationCapturing.CaptureMode = Surface does not seem an option because I want to densify the geometry first and then 3D-generalize it. And updating the Zs in the BeforeSketchCompletedEvent does not seem an option because I need this behavior only for a certain feature layer, both for new features and geometry updates.
