Hi all,
here is the workflow I've followed:
- create the Sewer Asset Package from ETL
- create the Utility Network from Asset Package
- activate the Attribute Rule "StructureJunction - Create Manhole Channel batch"
- run Evaluate Rules
- activate the Attribute Rule "Line - Snap to Manhole batch" (and disable the previous one)
I've tested the same workflow with the same data in two different environments:
- ArcGIS Pro 2.9.5 - UN vers. 5
- first rule OK
- second rule ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
- ArcGIS Pro 3.0 - UN vers. 6
Unfortunately the job must be done using 2.9.5.
Any idea?? Is it a bug?
