Hi all. I am not good at python at all. I have tried using other codes I found but am having no luck. I am just not good enough to see what I need to change.
I used the batch export attachment rules and created the tool to export out the images but I need to have the images labeled with the asset_number from the layer so we don't have to go through and label each one individually.
I have GlobalID that create the relation between the tables but need the asset_number from the layer to be the actual image file name.
Any ideas? I am working in pro 3.0
