Is there anyway to install PRO with the 'Enable Undo toggled on by default' checked. By default the check box is unchecked. The check box is in Settings -> Options -> Application -> Geoprocessing. We deploy PRO to users with a larger install package which includes 'hacking' some Registry settings. Is it possible to change the 'Enable Undo toggled on by default' to checked in the Registry? If yes, what is the setting name and value?
I'm open to other ideas to automate this task.
