As I am working with arcgis JS API 4.24. I want to bind an eventhandler to the view if a user clicks on the map:
mapStore.mapView?.on('click', (event) => {
const point = `point: (${event.mapPoint.latitude}, ${event.mapPoint.longitude})`;
console.log('click event1: ', point);
}This eventhandler shall stay active as long as a condition is true. If the condition is false I would like to remove exactly this handler and I would like to only use the standard view on-click handler. I can disable the eventhandle exactly during its execution but I want to leave it active for the duration of the condition... the ad-hoc removal would look like:
export const clickhandler = (active: boolean): void => {
const { mapStore } = Stores.getInstance();
if (active) {
const handler = mapStore.mapView?.on('click', (event) => {
handler?.remove();
} else {
console.log('click event1: ', 'disabled');
};I've seen some examples where they work with dojo/connect in arcgis JS API 3.x... Is there an equivalent in ArcGIS JS API 4?
