I am using the deep learning product to do the landuse and there is a problem.
Here is the error message:
Classify Pixels Using Deep Learning
Parameters
Input Raster Surface Reflectance_LC08_L2SP_089079_20130427_20200912_02_T1_MTL
Output Classified Raster C:\Users\Admin\Documents\ArcGIS\Projects\MyProject1\MyProject1.gdb\SurfaceReflect_ClassifyPixel3
Model Definition C:\学习文件\2022 Semester 2\Final Research\土地利用深度学习\LandCoverClassification.dlpk
Arguments padding 128;batch_size 4;predict_background True;test_time_augmentation True;tile_size 512;landsat_imagery_level 2
Processing Mode PROCESS_AS_MOSAICKED_IMAGE
Output Folder
Environments
Extent 152.607318628634 -27.5730888984295 153.480255433056 -27.3123415412645 GEOGCS["GCS_GDA_1994",DATUM["D_GDA_1994",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]
Cell Size 30
Processor Type GPU
Messages
Start Time: Friday, 9 September 2022 2:23:47 AM
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Unable to read pixels from the python raster function.
Function Read Error [Raster Function Template]
File "C:\Users\Admin\AppData\Local\Temp\ArcGISProTemp14780\LandCoverClassification.dlpk\ArcGISImageClassifier.py", line 275, in updatePixels
xyz = self.child_image_classifier.updatePixelsTTA(tlc, shape, props, **pixelBlocks).astype(props['pixelType'], copy=False)
File "C:\Users\Admin\AppData\Local\Temp\ArcGISProTemp14780\LandCoverClassification.dlpk\_unet.py", line 443, in updatePixelsTTA
all_activations = self.tta_predict(
File "C:\Users\Admin\AppData\Local\Temp\ArcGISProTemp14780\LandCoverClassification.dlpk\_unet.py", line 399, in tta_predict
int_surface = self.split_predict_interpolate(
File "C:\Users\Admin\AppData\Local\Temp\ArcGISProTemp14780\LandCoverClassification.dlpk\_unet.py", line 371, in split_predict_interpolate
output = self.model(patches)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\torch\nn\modules\module.py", line 889, in _call_impl
result = self.forward(*input, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\layers.py", line 136, in forward
nres = l(res)
nres = l(res)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\layers.py", line 150, in forward
def forward(self, x): return torch.cat([x,x.orig], dim=1) if self.dense else (x+x.orig)
RuntimeError: CUDA out of memory. Tried to allocate 412.00 MiB (GPU 0; 2.00 GiB total capacity; 1.11 GiB already allocated; 0 bytes free; 1.41 GiB reserved in total by PyTorch)
Python raster function's .updatePixels() method returned nothing.
nres = l(res)
nres = l(res)
nres = l(res)
nres = l(res)
Failed to execute (ClassifyPixelsUsingDeepLearning).
Failed at Friday, 9 September 2022 2:25:08 AM (Elapsed Time: 1 minutes 20 seconds)
