I'm building an Experience using the "JewelryBox" template and have run into some issues with Actions. Basically, if I set an Extent Change trigger within the Map Widget to filter data records in the Framework, any Filtering widgets that I've placed elsewhere in the Experience that act upon the map (either the standalone Filter Widget or the filter tool within the List Widget) fail. The mechanism of failure is as follows: if I go into Live View/Preview and try to use any of the end-user filter dropdowns (they're all set up as "Ask for Values"), no attributes show up within the filter dropdown and instead I am confronted with an infinite spinning loading wheel.
Concurrently and seemingly directly related, I'm having an issue where the map fails to load features when I zoom out to different extents in a somewhat buggy/unpredictable way.
All of these issues cease when I remove the Map Widget action.
Any help is greatly appreciated, and I apologize for how confusing this must sound! It is rather difficult to describe ExB bugs over text.
Cheers
