Using ESRI JS API Core 4.24
I have created a project on Next JS and trying to load the data(polygon) from a JSON source, which I have kept in a local folder. I am getting the json from getStaticProps and passing it to EsriMap component using bellow code..
import dynamic from "next/dynamic";
import React, { useState } from "react";
import fs from "fs/promises";
import path from "path";
const EsriMap = dynamic(() => import("../../components/esri_map"), {
ssr: false,
export default function index({district}) {
return (
<EsriMap districts={district}/>
export async function getStaticProps() {
const filePath = path.join(process.cwd(), "data", "district.json");
const jsonData = await fs.readFile(filePath);
const data = JSON.parse(jsonData);
return {
props: {
district: data,
First Try
import React from "react";
import { useRef, useEffect } from "react";
import ArcGISMap from "@arcgis/core/Map";
import MapView from "@arcgis/core/views/MapView";
import LayerView from "@arcgis/core/views/layers/LayerView";
import SpatialReference from "@arcgis/core/geometry/SpatialReference";
import FeatureLayer from "@arcgis/core/layers/FeatureLayer";
import Polygon from "@arcgis/core/geometry/Polygon";
import Graphic from "@arcgis/core/Graphic";
import SimpleFillSymbol from "@arcgis/core/symbols/SimpleFillSymbol";
import SimpleLineSymbol from "@arcgis/core/symbols/SimpleLineSymbol";
import Color from "@arcgis/core/Color";
import SimpleRenderer from "@arcgis/core/renderers/SimpleRenderer";
import Sidebar from "./sidebar";
export default function EsriMap({ districts }) {
var map, view;
const mapRef = useRef(null);
const {
displayFieldName,
features,
fieldAliases,
fields,
geometryType,
spatialReference,
} = districts;
// I am getting features properly
console.log(features);
useEffect(() => {
const map = new ArcGISMap({
basemap: "topo-vector",
const view = new MapView({
map,
container: mapRef.current,
extent: {
spatialReference: {
wkid: 102100,
xmax: 9318041.682582326,
xmin: 7685897.199114412,
ymax: 2134999.5715922136,
ymin: 1257953.6118566156,
zoom: 7,
// like this i can add the map service also, so scope is fine
// const districtLayer = new FeatureLayer({
// url: "http://xyz/MapServer/1"
// map.add(districtLayer);
const districtFeatureLayer = new FeatureLayer({
objectIdField:"OBJECTID",
geometryType:geometryType,
fields:fields,
spatialReference:spatialReference,
source:features,
map.add(districtFeatureLayer);
return (
<div className="flex flex-row h-full">
{/* <aside className="w-1/5">Table of content</aside> */}
<Sidebar/>
<div className="w-4/5" ref={mapRef}></div>
</div>
It is giving the error like this (firsttry.png enclosed)
- error: s
- details: {layer: l, error: s}
- message: "layerview creation failed"
- name: "layerview:create-error"
Second Try
var graphicsD =[
{geometry:
{features:features,
geometryType: geometryType,
spatialReference: new SpatialReference(spatialReference)},
attribute:fields
let featureD = [
spatialReference:new SpatialReference(spatialReference),
fields:fields,
source: graphicsD,
let layerD = new FeatureLayer({
title:"s",
source:featureD,
map.add(layerD);
It is giving error like this(secondtry.png enclosed)
- error: s
Can anybody guide where I am committing a mistake. in feature layer creation or preparing data for feature layer creation.
