Hello all,
Publishing our map services as map images, using Pro to Portal, we have encountered numerous layers where the symbology has been downgraded for Portal. Although this is expected behaviour, e.g. line layers, simple line symbols are supported. If other symbols are used, the feature service converts them to a simple line symbol that best represents the original symbol, I would be interested to find out other's experiences with downgraded symbology.
For example, a cartographic line symbol in the map document may be drawn as a simple solid line in a feature service client. If a line symbol is complex or has multiple layers, the feature service downgrades the line to best represent the original line symbol. “
This has been problematic as some symbology is nationally recognised for example Public Rights of Way and can no longer be represented in Portal if we publish as a registered feature layer/map image.
It would be really helpful if in Pro when selecting a symbology, there was an option for "Portal only symbology" so we knew what symbology supports, instead of receiving a message at the point of publishing the data that it will be downgraded.
I would be interested to know others experiences of downgraded symbology when publishing map images or registering feature layers in Portal.
Many thanks
