I rec'd a kmz file that has dots in the internal feature name, see image.
There are over 200 in the file.
My problem is I think this "." is causing the tool KML to Layer to hang. I left it running for over an hour and it never went beyond 2%.
Is this the reason it hangs? Should I just be more patient? It will take a very long time to rename all of these features in GoogleEarth.
EDIT: Here's what ended up working-
1) open the original KMZ, unzip to KML and remove the "." [still locked up the tool]
2) open the new KML in GoogleEarth and change the symbology
3) re-save the KMZ to a new name
4) KML to layer in ArcPRO for the win.
Not sure why changing the symbology would make a difference, but there you go. Thanks for the replies.
