I am trying to run the Trim Archive Hisotry tool in Pro on a non-versioned Feature Class with Archiving enabled. Unfortunatly, I get an error saying:
ERROR 003206: The trim date must be older than the date the map was taken offline. [The table, GIS.SDE.survey_v2_0, participates in a feature service that was used in an offline map. SDE.Ags_Fs, 01/16/2020 08:35:53 PM]
I cannot use an older trim date because it wont trim the correct data. How do you figure out what web map is creating this lock if the Feature Class is used in A LOT of services???
