I have a use case for uploading a map for field users to see, and then continually updating that map, while retaining the information field users will be inputting every day. I would like to be able to essentially add the hosted version of the map through the portal into modelbuilder so that I can add new polygons daily. I can't find a command within modelbuilder that will allow me to do that. I realize I can add these new polygons to the map saved locally, and overwrite layers, but then I will lose the information that the users give on the uploaded version of the map. I can't figure out a way to download those changes from the hosted map to the local map so that the overwrite layers command would work either. If anyone can point me in the direction of how to continually update a map in AGOL with modelbuilder, I would be greatly appreciative.
Damon
