When using the edit widget in Experience Builder, the widget loads layers from the map to the widget that should not be loading and are not editable services, in some cases it even loads a map service to the edit widget. The errant layers in the edit widget appear to be editable but they are not. I only want those services from the webmap that are marked as "editable" to appear in the edit widget, not any service from the layer list. This problem started appearing a few days ago (week of 06/20) and is intermittent at times but will eventually happen to any Experience Builder app. In my attached screenshot the layers showing in the widget are not feature services, they are map services and not editable. Does anyone know why these layers are appearing in the widget and how to remove them?
Using new web map, Experience Builder, and feature services and map services are coming from an Enterprise GIS server (10.8.1). Thank You.
