Add Geometry Attributes (Data Management)
The values in these fields are not automatically recalculated after edits. If you edit the features, you'll need to run this tool again to update the field values.
It would be great if those fields were dynamic, similar to the Shape_Length field in the attribute table, but as optional fields (they could be turned off by default, to avoid unnecessary performance hits). For example, it would be helpful to have dynamic fields for:
- Startpoint, midpoint, and endpoint
- Part count and point count
This functionality wouldn't necessarily need to be a GP tool. Instead, what if we could just open the Design > Fields window in ArcGIS Pro, and then just click a checkbox to make the geometry attributes visible? That might be ideal...just like we can do for the dynamic Shape_Length field.
I'm aware that those values can be calculated using attribute rules. That is technically possible, but some of those Arcade calculations are non-trivial, such as getting the midpoint.
Many of the fields in the "Add Geometry Attributes" tool would be helpful to a large number of organizations. Why make of us all fumble around with custom Arcade scripts to calculate them? Why not just do it OOTB through ArcObjects/default fields?
