I have a feature layer (points). So, I'd like to randomly select several points based on the value in one of the columns ('level_' column).
For instance, I'd like to randomly select 16 points of level 1 and 10 of level 2, then I will use the result to plan a route using plan_routes(). The thing is that I don't want the two results separate because I need them to be in the same feature so I can use them as input for planning the routes.
In the code below I queried the feature layer to get only the points of level 1 & 2.
# query parcels - level 1 & 2
m_levels = test.query(where="level_= '1' OR level_='2'")
m_levels
Thanks!
