Hi all,
I'm in the middle of building a web application with two layers that have photos under Attachments in the attribute table and it shows up as a link on the web application, but in Map Viewer/Map Viewer Classic, I have it set up so that it automatically displays the photos in the popup. I'd like to have this option in the Web Application, but I'm not seeing a solution yet. I've seen this post, but the toolbox keeps failing in ArcMap Pro, and I'd have to run a task scheduler and use ArcMap Pro, I'd rather not do that if I don't have to.
Has anyone run into this issue before and did you find a solution?
Thank you all.
