Hello all,
I am trying to use several instances of the smartEditor widget within one WAB application. As I cannot place it again I duplicated the widget and renamed it (and replaced the name as I believe everywhere within the files). While the widget itself seems ok, I am not able to use both instances, even if I close one before using the other. I keep getting the error "Create widget error: widgets/drawAOI/Widget" (respectively if I open the drawAOI first, then the SmartEditor widget brings the error). From the console I get this error:
create [widgets/drawAOI/Widget] error:Error: dijit._WidgetsInTemplateMixin: parser returned unfilled promise (probably waiting for module auto-load), unsupported by _WidgetsInTemplateMixin. Must pre-load all supporting widgets before instantiation.
