When using a custom print service with our own layouts, currently at Enterprise 10.8.1 we have to recreate the print service and overwrite the layout information accompanying it. Following this we refresh the print task and layout URLs in the LocalMaps 2.3.1 admin UI. This completely resets the print layouts that are available to all maps and turns them all on, while also limiting the export options to just PDF and JPEG. This means that all maps have to have their print settings reconfigured.
What I'd suggest is an 'update print layouts' or 'add/remove layouts' option/button in the LocalMaps admin UI, so that when the print service is replaced (or overwritten if this becomes a viable option from ESRI) any templates that existed before and were either unassigned or assigned to a map in LocalMaps have their settings retained, but any that are either removed or added to our layout templates folder would then be removed from/added to LocalMaps. It could either be automatic or an interactive selection from the layout template list. Their particular settings could then be configured in the admin UI
