We are starting to implement ArcGIS and deployed the gas distribution management solution for online (not Enterprise). We have used curb valves for some residential services and service valves for commercial services in our system. These are not an option within the solution. We have created new layers and fields within layers in other maps, but how can we create these new layers or add new fields to existing layers within the solution to maintain the designed support and functionality of the solution?
Sorry if this is an easy task, we are new to all of this.
I attached a picture of the GasSystem feature layer (hosted) Valve layer. The default valves are under the asset group but we can not edit or add anything here like other layers. Is it because of the solution package?
The other picture is the Gas Asset Collector showing the default valve options (excess floe valve, Flow valve & relief valve). This is where we would like our new curb valve and service valve options to be located.
