I have an issue when trying to create features with z-values for sewers using the Utility Network. In this case, I am trying to create sanitary sewer manholes from the Structure Junction > Vault group. I set the elevation in the elevation group of the edit tab. If I put in a whole number (e.g. 620), it will create the feature without problems. It will also take 1/4 values (e.g. 620.25, 620.5, 620.75). When I try to set it to a number with any other decimal value (e.g. 620.37), I get an error:
Failed to create Manhole.
Invalid Geometry [
Rule name: StructureJunction - Manhole
Elevation Attributes,
Triggering event: Insert,
Class name: StructureJunction
I have checked the Attribute Rules for Structure Junctions and the only apparent rule for the z-value is Round z to 2 sigfigs. I also did not have this issue with the stormwater manholes of the structure junction group, which use the same data type (double) for elevation.
