I'm working to develop a tool that converts JSON data pulled from an API into a feature class to be stored in an ESRI file geodatabase. I'm currently testing the functionality in a Jupyter notebook within an ArcGIS Pro project but my goal is to eventually convert my script into a geoprocessing tool that can be used by non-developer users. However, I've gotten stuck in the prototype phase and cannot figure out if I am running into a bug or if there is an issue with my code.
Here is my code:
import requests
import arcpy
from arcgis.features import GeoAccessor, GeoSeriesAccessor
import pandas as pd
# pull public geojson data from socrata
r = requests.get('https://data.bayareametro.gov/resource/ufzj-38uk.json')
j = r.json()
df = pd.DataFrame.from_dict(j)
# Convert to Spatially Enabled Pandas Dataframe
sedf = pd.DataFrame.spatial.from_df(df, geometry_column='shape')
# Export Spatially Enabled Pandas Dataframe to FGDB Feature Class
sedf.spatial.to_featureclass(location='equity_priority_areas_2020')
This is the error message I received:
ValueError Traceback (most recent call last)
In [22]:
Line 5: sanitize_columns=True)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\geo\_accessor.py, in to_featureclass:
Line 2388: has_m=has_m,
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\features\geo\_io\fileops.py, in to_featureclass:
Line 853: df.columns = original_columns
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\generic.py, in __setattr__:
Line 5478: return object.__setattr__(self, name, value)
File pandas\_libs\properties.pyx, in pandas._libs.properties.AxisProperty.__set__:
Line 66:
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\generic.py, in _set_axis:
Line 670: self._mgr.set_axis(axis, labels)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\internals\managers.py, in set_axis:
Line 221: f"Length mismatch: Expected axis has {old_len} elements, new "
ValueError: Length mismatch: Expected axis has 42 elements, new values have 41 elements
Here is what I tried to resolve the issue:
I reviewed the GeoAccessor class method [to_featureclass](https://developers.arcgis.com/python/api-reference/arcgis.features.toc.html#arcgis.features.GeoAccessor.to_featureclass) API reference and tried to set the path to the File Geodatabase explicitly as well as provide explicit values for the `has_z`, `haz_m`, and `sanitize_columns` parameters as shown below and got the same error message.
sedf.spatial.to_featureclass(location='Z:\Documents\ArcGIS\Projects\Socrata_to_ArcGIS\Socrata_to_ArcGIS.gdb\equity_priority_areas_2020',
overwrite=True,
has_z=False,
has_m=False,
I seem to always run into issues when trying to perform seemingly basic things with these spatially enabled dataframes.
