In the Fields tab in ArcGIS Pro:
Currently, if we rename a field, the field alias stays the same as it was before we renamed the field:
We often don't think to update the alias when renaming a field. The old name doesn't apply anymore, and is often downright misleading. Especially since the alias is used as the field header in the attribute table, not the field name.
Intuitively, when renaming a field, we'd expect the alias to be reset to the field’s new name.
Could Esri consider changing that behavior?
ArcGIS Pro 2.6.8
