I'm trying to duplicate a layout template, in order to have the exact same text properties/placement/color/size etc. I know you can duplicate a layout directely in the Catalog or save it as a layout file (pagx). Everything works fine up to that. The problem I encounter is if I try to use that exact template and change the map frame it refers to. Then, all my legend elements go bezerk.
Here is an example:
(good original legend)
(bezerk legend after changing the map frame)
Here are the legend properties:
- nothing is synchronised with the map (visibility, order, new layer, etc)
- adjustment strategy is "adjust window" (because I want to specify the text size)
- fixed column width
So can anyone exeplain with anything would change just by switching map frame? Thank you!
