It's great that I can use an arcade expression to display related table information in a feature's pop-up. Are there any plans, with Map Viewer (Beta) to be able to symbolize based on those values?
I have aa "Incident Report" point that has two related tables (one for investigation and one for repair). I created arcade expressions to show "Investigation Date" and "Repair Date" in the Incident Report point's pop-up, but I need the ability to not show points on the map that have been investigated, to help keep the maps a little cleaner for our dispatchers. I am working to have spatial views created of the point and investigation and the point and repair.
The only solution I've come up with so far is to create an arcade expression that removes the point from the map after a certain amount of time. Even when it comes to adding the spatial joins to the map, it will just be points stacked on top of each other, which really isn't ideal either.
