Is it possible to use a personalized number for the GUID field?
I'm getting started with creating a Survey using Survey123 and connecting the data it collects to a feature layer in Field Maps. One the main steps seems to be linking the two with the GUID number. If this dataset already uses personalized ID numbers for the data being collected, could those numbers be used instead or does it have to be the number generated by the GUID tool?
Thank you,
Amy
