Hi all,
we have an installation of a high available portal 10.8.1 in windows with a federated ArcGIS Server. Everything works perfectly. We decided to upgrade to the latest version 10.9.1.
We started installing the portal software in both machines, as described here. Installing the software worked perfectly for both machines. We run the installation simultaneously as suggested in the link above.
The portal windows service restarted. Then we noticed that only the javaw.exe was running and no java.exe was running.
We followed the instuctions here to make sure that the C:\Program Files\ArcGIS\Portal\framework\runtime\tomcat\conf\server.xml is correctly set and that the indexes doesn't have any issue.
The portal logs have no error.
The elastic logs mention "can not be imported as a dangling index, as index with same name already exists in cluster metadata" for all the indexes.
The windows Event viewer mentions that "postmaster.pid does not exist".
We run a portal repair with the windows installation and we restart the whole machine but it didn't work.
Does anyone have a similar issue or any experience? Any help is appreciated :-).
