Hi community,
We are thousand of people using ArcGIS Desktop 10.6.1 and working in a SDE of a transportation system.
We basically create/delete/update (at the same time) the features of every layer of the table of contents (for example the bus stops). To create a point/bus-stop in the SDE, I do it manually and I have to retrieve the values of every field from my CSV/Excel file ! At the end, my bus-stop is created and a unique OBJECTID is generated and only then I can save the changes so they can be visible to the rest of users.
I need a way to import a shapefile (that content >100 points/rows), using the ModeldBuilder, to the SDE knowing that the bus-stops database has a spatial index and is represented by 10 fields/columns with different types.
Can you please show me how to do this ? This will literally saves me a hundred of hours !
Thanks, P92.
