Hi
I'm having an issue with model builder. I've a workflow which iterates through to create an IDW for each catchment in a rainfall point file. I then need to use Extract by Mask to clip the IDW raster to the catchment before I reclassify.
When I do this manually using the Extract by Mask tool this works but when I try it as part of my model it hits the error "No spatial reference exists. Failed to execute".
I've checked and the points layer and IDW have spatial references. I've even set a default in the model builder tool. When I try Extract by Mask on it's own in model builder it still won't work but works as a normal geoprocessing tool.
Any thoughts?
