Hi everyone,
Can anyone help with using the Multiprocessing.Pool() module to get my nested loop script running via multi-processing? I tried doing it myself but couldn't work out how without getting errors.
I am working with very big datasets which take hours to days to run at each stage of the loop so am in need of a way to make this significantly faster.
See script below:
#Import system modules
import arcpy
from arcpy import env
# define list values
list1 = [ 'x', 'y', 'z']
list2 = [ 'a', 'b', 'c']
for x in range(len(list1)):
for y in range(len(list2)):
try:
#Check out the Network Analyst extension license
arcpy.CheckOutExtension("Network")
#Set environment settings
env.overwriteOutput = True
#Set local variables
inNetworkDataset = "D:/RoadNetwork.gdb/RoadNetwork_ND"
#verify layer name
outNALayerName = list1[x]
chunk = list2[y]
#set variables
impedanceAttribute = "Distance"
inFacilities = "D:/facilities/" + chunk + ".shp"
polygonBarriers = "D:/barriers/" + outNALayerName + ".shp"
outLayerFile = "D:/outputs/" + outNALayerName + "_" + chunk + ".lyr"
#Make a barrier feature layer
barriersLayer = arcpy.management.MakeFeatureLayer(polygonBarriers,"PolygonBarriers").getOutput(0)
#Create a new service area layer.
outNALayer = arcpy.na.MakeServiceAreaLayer(inNetworkDataset, outNALayerName,
impedanceAttribute, "TRAVEL_FROM", "60", "DETAILED_POLYS", "NO_MERGE", "DISKS",
hierarchy = "NO_HIERARCHY", poly_trim_value = "100", restriction_attribute_name = ["OneWay"])
outNALayer = outNALayer.getOutput(0)
subLayerNames = arcpy.na.GetNAClassNames(outNALayer)
facilitiesLayerName = subLayerNames["Facilities"]
polygonbarriersLayerName = subLayerNames["PolygonBarriers"]
#Create field mappings for loading barriers
fieldMappings = arcpy.na.NAClassFieldMappings(outNALayer,polygonbarriersLayerName)
fieldMappings["BarrierType"].defaultValue = 0
#Load the facilities and barriers
arcpy.na.AddLocations(outNALayer, facilitiesLayerName, inFacilities, "", "")
arcpy.na.AddLocations(outNALayer, polygonbarriersLayerName, polygonBarriers, fieldMappings)
#Solve and save the service area layer
arcpy.na.Solve(outNALayer)
arcpy.management.SaveToLayerFile(outNALayer,outLayerFile,"ABSOLUTE")
except Exception as e:
# If an error occurred, print line number and error message
import traceback, sys
tb = sys.exc_info()[2]
now = datetime.now()
print now.strftime("%d%m%Y-%H%M%S")
print "An error occurred on line %i" % tb.tb_lineno
print str(e)
