so i have a point dataset stored in AGOL as a feature service containing a little over 12 million rows and i need to update one field based on some criteria
my initial thought was to create a script to do it in Notebooks in AGOL
updCount =0
while True:
try:
updSym = slry.query(where="PROV_src='aaa' and Symbology is null", return_all_records = False, result_record_count = 2000)
print(len(updSym))
if len(updSym) ==0:
break
else:
for x in updSym:
#loops all returned records and updates the symbology field to 5
print("ObjectID:- {0} -- {1}".format(x.attributes['OBJECTID'],x.attributes['PROV_SRC']))
x.attributes['Symbology'] = 5
#commits the edits
res = slry.edit_features(updates = updSym.features)
resstr = str(res)
#counts the number of success = true in the results and adds it to the completed ones
updCount = updCount + resstr.count("'success': True")
print("updated:- {0}".format(updCount))
except:
print("error")the script above if just for one of the criteria and it does work but its slow i think its running about 20 seconds per 2000 rows...
its running the notebooks as standard and not advanced not sure if that makes a difference
is there a better way short of updating the original FGDB locally on my laptop and re-publishing it
Stu
