I have a web map that is feeding a dashboard. The map contains a single hosted feature layer. I overwrote that hosted feature layer - no errors, publish succeeded. The overwritten layer is fine. I can open it in the map viewer, and it looks like what I expect.
When I open the web map that contains this layer, I get an error message:
The layer, <layer name>, cannot be added to the map.
I can add the layer back into the web map, since there is nothing wrong with it at all (that I can see), but the dashboard will not 'see' the layer (even though it's the same layer) and will need to be reconfigured.
Is this a common problem? Has anyone else experienced this? If it is unique to our system, then I do not expect anyone to troubleshoot it here, but I am just asking in case there is a history of this problem I can learn from.
Thank you,
Randy McGregor
